Results 1 to 10 of 10
12-14-2013, 08:08 AM #1
Anyone Using a 1.75 filament on a i3 Prusa Mendel?
I have several new spools of 1.75 PLA and was thinking of adding a 1.75 J Head to the i3 so I could use them up. Anyone using a 1.75 hot end instead of the normal 3mm hot end? If so, are there any know issues? Thanks
12-18-2013, 08:15 AM #2
Interesting. I too have some 1.75 PLA's that I wouldn't mind using. Is this something that is doable?
12-18-2013, 09:05 AM #3
My only concern is will the Mk7 Drive Gear on the extruder bottom out on the pressure gear with the smaller diameter filament? My son has both i3 Prusas but I will get mine back next week. I may try it and see how it works? I'll let you know.
12-23-2013, 08:59 AM #4
John, please let us know how it goes. I'm curious as to if the 1.75 will work as well.
12-27-2013, 06:45 PM #5
I have a Prusa I3 which is setup for 1.75mm filament. What occurred for me is there was a hollow cavity in the hole between the hobbed bolt and front end. If you have any Teflon tube with a internal diameter of 1.75, you can cut it to that size. Insert it under the hobbed bolt in the filament path as a guide. The insulator underneath should keep it in place. I hope this applies to your configuration.
12-29-2013, 08:15 AM #6
- Sep 2013
- 35
DR1983, did this work for you, or are you just assuming this will work? JohnA, have you given it a try yet?
12-29-2013, 09:28 AM #7
I have not. My son dropped off my i3 with two rolls of PLA so I have put this project on the back burner. I will have to order a 1.75 J head to give it a try.
12-29-2013, 10:07 AM #8
12-29-2013, 01:19 PM #9
- Dec 2013
- 8
Because of the larger hot cavity with the 3mm nozzle, retraction will probably suffer with 1.75 filament
01-22-2014, 01:10 PM #10
images of first print
This is to confirm that my recommendation works on my setup. 20140122_024551.jpg20140122_022927.jpg This was the first print.
