Results 1 to 10 of 172
11-29-2014, 09:24 AM #1
Well... 2 or 3 things were on the list to make you happy.... But I suspect you want your LCD Panel to work the most.
I don't have an LCD Panel, but I wanted to use the M600 Filament Change command those people wrote to promote the LCD Panels. So I had to add a couple of routines to provide functionality that the LCD Panels normally provide.
First... Save your entire code base before you make any changes. Probably you won't be able to make this work first try and we don't want to lose forward progress.
First, go into Marlin_main.cpp and delete this code. These are the duplicate routines that you wont need:
Code:// Roxy substitute routine to provide user confirmation easily on a PrintrBoard. // It looks at GPIO PC1 pin 11 value for input value change. // This routine looks for a button press to confirm everything is OK. // This allows the firmware to provide the Filament Change feature without // an LCD panel installed. The switch is wired from the Expansion Port 2 // header pin closest to AT90USB1286 chip to a switch that can connect it to // Ground. #define FILAMENTCHANGEENABLE #ifdef FILAMENTCHANGEENABLE #ifndef ULTIPANEL bool lcd_clicked() { int pin_being_examined; int ii, iii, jj; pin_being_examined=12; // This is PC1 on PrintrBoard pinMode(pin_being_examined, INPUT_PULLUP); // Set it to Input with a pull up if it hasnt delay(50); // been used since RESET. iii = digitalRead(pin_being_examined); // Get the current state of pin. return !iii; } void lcd_pressed() { while( lcd_clicked() != 0 ) // Wait for the switch to be released ; delay(50); while( lcd_clicked() != 1 ) // Wait for the switch to be pressed ; delay(50); } #endif #endif
11-29-2014, 09:56 AM #2
- 114
Question for you. After g29 the z raises, where did you set this?
11-29-2014, 10:00 AM #3
Probably, you are talking about this code at the very very end of the G29:
Code:do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS] + Z_RAISE_BETWEEN_PROBINGS); #ifdef Z_PROBE_SLED dock_sled(true, -SLED_DOCKING_OFFSET); // correct for over travel. #endif // Z_PROBE_SLED retract_z_probe(); } break; #ifndef Z_PROBE_SLED case 30: // G30 Single Z Probe
