Results 11 to 20 of 21
Thread: Newbie
10-26-2014, 05:05 PM #11Hex3D - 3D Printing and Design http://www.hex3d.com
10-31-2014, 12:44 PM #12
- Oct 2014
- 93
is this the oil and grease i sould look at :
oil http://www.ebay.co.uk/itm/251616434690?_trksid=p20 60778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
grease : http://www.ebay.co.uk/itm/3214176531...%3AMEBIDX%3AIT
if so ill order them right away.
11-01-2014, 07:52 PM #13
They will do fine, and you could even use sewing machine oil on the bearings, I use the Tamiya stuff because I run alot of R/C cars so it's something I always have handy, we're only talking a few drops here and there so it will last some time. The Tamiya ones have a needle like tip, so it's a bit easier to apply. That grease is pretty awesome too, it has Teflon in it, it's really resistant to heat (not that the Z shaft spins all that fast) but more is better than less yeah ?
11-02-2014, 10:36 AM #14
- Oct 2014
- 93
cool ill get some ordered then,
i now have another problem, while cleaning the feed motor, i managed to round out the aluminium bar that hold the extruder head in, so now it just falls out. any idea where i can get a spare ????
http://kolobus.co.uk/collections/spare-parts
this looks like it has the right one ??? could someone confirm this
11-02-2014, 10:49 AM #15
looks like the right bit.
Well there's a page of bits - presumably you mean this bit ?
Interesting website too :-)
11-02-2014, 11:05 AM #16
- Oct 2014
- 93
that was the bit i was cleaning, lots of abs in the grooves
http://kolobus.co.uk/products/extruder-metal-bar-mount
this is the part i need if this is the right one
11-02-2014, 05:48 PM #17
That is the same block as the flashforge, so yeah will work fine - def much cheaper than getting one buy buying a new extruder set (did that stupidly once.. never again...)
11-05-2014, 12:44 PM #18
- Oct 2014
- 93
well the new alu bar arrived yesterday, and as though was missing the holes for the grub nuts that hold the nozzles in place, so after a few emails (kolobus customer service is very good and helpful), i decided to keep it and try and get it drilled and threeded myself.
1 phone call later to a friend who works in metal work fabrication and the job was set for today. while waiting and not being able to print jack i upgraded the firmware to 7.7 sailfish
so today after work i took the old alu and new alu bar to my mate who as expected knew exactly the right size, 20 mins later (i think he got a call mid job) and my new alu bar was gtg (good to go), while there i asked if it was possible to use steel or something stronger than alu, was told it can be fabricated in any metal, so there a future idea, how often do these parts die????
so im now home and after much fustration, the holes are drilled on the reverse, meaning the nozzle adjustment now requires a strip down, but they are a better fit as there is more metal to screw into.
just finished a test block, and lefty is working fine (love the little noise to tell you its finished).
now on the righty. Prints perfect as well.
now to test dual extrusion (something i have not been able to try due to unlevel head)
geoff wtf is the new end of build screen trying to tell me, before i just got time. now it displays
time : 0h 12m (i know what that is)
filament : 0.6982m (??????)
(cannot print copy) (?????)
-> main menu
helpLast edited by Ghosty; 11-05-2014 at 01:05 PM.
11-05-2014, 01:44 PM #19
- Oct 2014
- 93
ok so now with this new fw my x axis is way off, like it dont even print on the platform off
11-05-2014, 05:11 PM #20Hex3D - 3D Printing and Design http://www.hex3d.com
New to 3d printing looking for...
Yesterday, 12:56 AM in Tips, Tricks and Tech Help
