Results 21 to 30 of 40
10-20-2014, 10:18 AM #21
I have a new extruder mounting system in the works. First samples are being cut right now. If anyone is interested in the first samples PM me. I am going to sell below my cost in the initial batch. The initial tooling is very expensive so just looking to recoup some of the costs.
Here is a sample of what I will be offering. It is a complete redesign of the cooling bar and filament guides. All in Machined aluminum. New heatsinks will be included.
As you can see in the picture. I am using a clamping bolt from the sides. This will allow both extruder mounting tubes to be loosened and then you can jog the build plate up until both touch the plate. Then you can just tighten the clamps.
In addition, the heatsinks are much more user friendly. No more nylon spacers and screws that hold the steppers through the fan. The steppers and Heatsinks bolt directly to the the cooling bar. Then the fans mount to the heat sinks with screws at the top.
10-20-2014, 12:41 PM #22
- Burnley, UK
- 1,662
10-20-2014, 02:28 PM #23
from where ?
I know the buggers are out there - just don't want to buy from a dozen different suppliers to find the one that fits my machine.
Ah I think the wanhao uses a different extruder. It's a lot more expensive than the flashforge so I'm guessing it's not identical.
We could meet up and compare machines - can't think of any other way of finding out the difference :-)
You're about 110 miles away - which could be as a short as 2 hours, depending on delays on the m6 :-)
Or you could measure your nozzle and I'll measure mine and we'll see if they're the same. That's probably a more practical approach :-)
The problem is you can get the flashforge nozzles from the states for not cheap money - or things on ebay that are really cheap but either the wrong thread or hole not big enough for the tube.
And there's no way of knowing without buying. I have yet to seea supplier on ebay use apicture of the end of the nozzle so you can't tell how large the bore is.
My mate has access to industiral tool making kit, so I might just buy a bunch of cheap nozzles and get him to drill them out to the right diameter.
I'd also like some spare tubes - but again can't find any uk suppliers - or chinese ones come to that.
I think I'm the old style nozzle, certainly looks like that in the pictures.Last edited by curious aardvark; 10-20-2014 at 02:39 PM.
10-20-2014, 02:41 PM #24
- Burnley, UK
- 1,662
I bought 10, I can send you a couple to try. These are 0.3 but you can bore them out if you want.
10-20-2014, 02:48 PM #25
if you've got some digital calipers just measure the thread length to the hexagonal piece and the hexagonal piece to the tip of the nozzle and the internal diameter of the main bore.
And i'll compare that to mine :-)
Thanks for the offer - but if they're the same I'll just buy some myself :-)
these italian guys on ebay seem to do them and down to 0.2mm diameter as well dargonfly.
http://www.ebay.co.uk/itm/ESTRUSORE-...item4d2274ba47
But they want £6 postage for something that might weigh 5 grams.
You could probably tape it to a postcard and it'd get here.
I think I'm either a mk7 or mk8 extruder. Probably a mk7 looking at the ebay adverts for the machines.
I have no idea what the difference is or how you tell which is which.
10-20-2014, 02:54 PM #26
- Burnley, UK
- 1,662
Pictures
The thread is a standard M6.
These are the ones I bought:
http://www.aliexpress.com/snapshot/6189638840.html
10-20-2014, 03:00 PM #27
- Burnley, UK
- 1,662
I don't see that thread length is important really. You just screw it in all the way and then screw the heat transfer tube down tight to it.
10-20-2014, 03:10 PM #28
The Flashforge threads are M7 x 1
It is better to screw the nozzle into the heat transfer tube. Otherwise you will have to fully disassemble the hot end to reseat the heat tube to the nozzle.
You should be able to do most maintenance with the hot end assembled and installed in the cooling bar. Just heat and use a wrench to unscrew the nozzle from the bottom. The teflon tube will generally come out with the nozzle.Last edited by jfkansas; 10-20-2014 at 03:16 PM.
10-20-2014, 03:22 PM #29
- Burnley, UK
- 1,662
They must be completely different from the Wanhao then. The nozzle and the heat tube both screw into the heat block. The nozzle does not screw into the heat tube.
10-20-2014, 03:28 PM #30
Yes, must be different. The teflon tube inserts about 5mm into the actual nozzle then the rest of the teflon tube goes up the heat tube to almost where the filament enters. I am working also on a new heaterblock and heat tube that is all metal and takes the 6mm threads, but still goes into the ~7.8mm opening of the flashforge cooling bar.
