Quote Originally Posted by 3DPBuser View Post
So was it found that it could vary the infill by X-Y, if you have different models?
Hi 3DPBuser, can you explain what you mean?
If you are asking if different infill patterns are possible then: yes and no.
The only infill pattern possible in Simplify3D is straight lines.. BUT you can choose at which angles these lines are placed and in which orders these angels come up.
Standard is -45 & 45 meaning you're getting a cross-pattern. But if you prefer to place these lines horizontal and vertical then that's possible to by using 0 & 180. OR you can go funky and do it 'hex' like by using 0 & 60 & -60.. so a lot of options depending on what you want, but a 'true' hex pattern like in Makerware is not available in this software.
