Results 1 to 5 of 5
09-30-2014, 09:15 PM #1
- Sep 2014
- 4
WPT 3D Printer Professional printer for everyone starting 499
INDIEGOGO LINK :https://www.indiegogo.com/projects/w...yone/x/8040994
Buy a professional Supersize 3D printer with a great price starting 499 WITH WORLD SHIPMENT INCLUDED
Professional affordable 3D printer only
$499 WITH WORLD SHIPMENT INCLUDED
Most of great 3D printer With a big printing size and high quality printing have the same problem....... IS TOO EXPANSIVE , (Like MakerBot $2499 ) SO we introduce the new BIG SIZE printer with 5 time cheaper than Most great quality printer on the market
The impotance of size
If you intend to make more practical prints think twice before purchasing a tiny sized 3D printer. WTP has a super printing size (250x250x300 mm, approx. 12x9x9 in). WPT is one of biggest 3D printer in its class.
Print without computer (Standalone printing)
Our printer has a 3X8cm LCD display control panel , you can transfer stl file direct to the printer than WPT can print without needing a computer . you can also control everything of printer in the control panel like temperature speed ........
Heatable build platform ,no bending or warping
one of the most 3D printer problems is that your printing object get warp or bending, with the heatable build platform , the object will never have the bending or warping problem
Removable platform
a removable build platform can solve the problem of damaging 3D printer when removing the printed object
Technical specifications- Printer Dimensions: Width: 43cm (16.9”), Length: 43cm (16.9”), Height: 34cm (13.4”)
- Max object dimensions: Width: 250mm (~9”), Length: 250mm (~9”), Height: 300mm (~12”)
- Printing material (filament): PLA, ABS, Nylon
- Filament size: Standard 1.75mm from any source.
- Nozzle diameter: 0.4mm
- Min layer height: 45 microns
- Filament type: non-proprietary ($29/kg)
- Total weight: 17kg
- It can also be used with any Windows, Mac, or Linux based system.
- USB-Compatible connection.
- Standalone printing from USB flash drive.
- Heatable and removable build platform.
- Replaceable nozzle.
- Best use between 100 and 300 micron layer resolution.
- 15 micron X and Y positioning accuracy.
- White interior LEDs.
10-01-2014, 08:15 AM #2
- Dec 2013
- Georgia
- 934
This guy has five projects, three in progress. All with big promises, low prices and flex funding. Two are passed their delivery date with zero updates and all comments hidden. I'm not going to make accusations, but you can draw your own conclusions from the facts.
Also I'm going to let you know right now that it was bad form to copy and paste the thread in the General 3D Printing Discussion forum. I will leave it because it might spark some discussion, but other mods might not be so kind.
10-02-2014, 11:50 PM #3
I absolutely do not believe this machine will print at 400mms.
I call shenannigans. When they change it over it still isn't printing at 400..Last edited by Geoff; 10-03-2014 at 11:00 PM.
10-03-2014, 12:24 AM #4
The display reaches 400, so it must be true. Better screw it down to the table before you try it though.
10-10-2014, 07:18 PM #5
The campaign ad is riddled with spelling errors,some good ones like "The Impotence at Size"
So far they are still at $1497 of their $60,000 goal, it's not looking good.Hex3D - 3D Printing and Design http://www.hex3d.com
05-13-2024, 03:08 PM in 3D Printer Parts, Filament & Materials
