Results 1 to 10 of 69
10-07-2014, 05:43 PM #10
Remember if you are using makerware especially, the infill is across the entire model on the build plate.
Example...
lets say you print an entire chess set on one plate, all pieces, in one print and you set it to 10% infill.
It's not going to infill each chess piece at 10%. It is going to fill the entire plate at a 10% ratio, so some pieces will be completely hollow, and some might have infill.. some might have alot, a little, or none.. depending on where they are placed on the bed.
So imagine that chainmail is a chess set, too low infill and you will find some links get none, and some do.
However, if you print 1 single item and set it to %10 infill, that item gets the entire %10 infill. The chainmail I'd be doing at 3 shells, or 50% infill, because at 3 shells it omits the infill because the links are thick enough.
