Results 1 to 10 of 69
10-10-2014, 04:12 PM #1
Did another try with ABS, got it working!
But, I had a hard time removing the raft. Still some left on my model. Tried another print increasing raft offset, separation and lowering infill to 30%. Got some sag on my lines. But easier to remove the raft
10-10-2014, 07:13 PM #2Hex3D - 3D Printing and Design http://www.hex3d.com
10-10-2014, 09:28 PM #3
Nice! That will be really interesting to see.
Yay!
Today's print took just under 12 hours- needed lots of supports which removed pretty cleanly. I do feel like I see imperfections more in this dark blue color. Also- it turned out really shiny. Not sure why- is it just the design? Anyway, I'm very happy with the level of detail you can get from the flashforge.
Anyone know how I rotate pics? Also, on that last one- see the roughness from the supports I removed? I tried sanding it and I feel like it looked worse. Maybe I need finer sandpaper... do you guys ever sand your pieces?
10-11-2014, 02:22 AM #4
Looks good! What settings did you use for it?
You always see imperfections better on darker and/or glossier colors. That's why I never trust printers (or painters) that only show white and/or matte products..
I prefer printing in glossy dark blue PLA. Gives me a very good visual of what settings I need to tweak to get better results.
I have filed a print sometimes, never used sandpaper (sandpapering small things with my large fingers is not doable.) But from what I've heard; sanding PLA is a bit more difficult then lots of other material. Just start with 200-300 grit and gradually move up to 1000.
But if possible; try making support that easily break of (or don't use any at all) to save a lot of time.
10-11-2014, 06:57 AM #5
Thanks for printing my Model
If you want to clean up sanding marks, use a cigarette lighter VERY gently on it, they will dissapear like magic. Easy way to rotate pictures is windows office picture manager, if you have Office.
I sand alot of prints, mainly support removal spots to clean them up, I use a small butane torch set to low and lightly flick over the white marks from sanding and supports.Hex3D - 3D Printing and Design http://www.hex3d.com
10-11-2014, 09:08 AM #6
Its ABS- layer height was .0.1700mm. Trying to find that sweet spot between high and medium quality. Everything was pretty much default S3D settings except I removed the brim and slowed down the first layer speed. I've been having problems with the brim not laying down good and creating little strings that then catch on the extruders and mess up the first layer. I haven't seen a way to slow down the speed of the brim because I think that would solve the problem. So I just took it out and slowed the first layer. That seems to be working ok. The supports were auto generated by s3d and came off easily. No problems at all. They just leave that tiny bit of roughness that really shows up in the darker color. I do love the way the dark colors look though. I can see why you use them.
I didn't realize that was yours!!! I downloaded quite a few things to try out a while back. I think the Groot head I printed was yours too. Those two things are my most favorite things I've printed to date. Thank you for sharing them. They are so well done. Now that I've tried several different Thingiverse designs, I can really tell the difference in quality of the various choices. You are really good at sculpting great detail that prints beautifully. Nice job man. :-) My husband is a HUGE superman fan, so I printed that one for him.
I will definitely try your tip about the heat to smooth the roughness. That sounds like a great idea.
