Results 1 to 10 of 69
10-11-2014, 06:57 AM #1
Thanks for printing my Model
If you want to clean up sanding marks, use a cigarette lighter VERY gently on it, they will dissapear like magic. Easy way to rotate pictures is windows office picture manager, if you have Office.
I sand alot of prints, mainly support removal spots to clean them up, I use a small butane torch set to low and lightly flick over the white marks from sanding and supports.Hex3D - 3D Printing and Design http://www.hex3d.com
10-11-2014, 09:08 AM #2
Its ABS- layer height was .0.1700mm. Trying to find that sweet spot between high and medium quality. Everything was pretty much default S3D settings except I removed the brim and slowed down the first layer speed. I've been having problems with the brim not laying down good and creating little strings that then catch on the extruders and mess up the first layer. I haven't seen a way to slow down the speed of the brim because I think that would solve the problem. So I just took it out and slowed the first layer. That seems to be working ok. The supports were auto generated by s3d and came off easily. No problems at all. They just leave that tiny bit of roughness that really shows up in the darker color. I do love the way the dark colors look though. I can see why you use them.
I didn't realize that was yours!!! I downloaded quite a few things to try out a while back. I think the Groot head I printed was yours too. Those two things are my most favorite things I've printed to date. Thank you for sharing them. They are so well done. Now that I've tried several different Thingiverse designs, I can really tell the difference in quality of the various choices. You are really good at sculpting great detail that prints beautifully. Nice job man. :-) My husband is a HUGE superman fan, so I printed that one for him.
I will definitely try your tip about the heat to smooth the roughness. That sounds like a great idea.
