Results 1 to 8 of 8
09-26-2014, 11:48 PM #1
Hi Ken, the white plastic tubes I assume are PTFE tubing, which is heat resistant and is most likely used to go into your hot end nozzle to align the filament, but you probably already have some in there if they are spares.
If the filament is not feeding through the other extruder, its possible there is still some gunk in there, I would heat it up really hot to like 250c, 260c and see if that melts the factory testing goop out of there.
09-27-2014, 04:37 AM #2
- Sep 2014
- 51
OK Solved ... My In-Experience, I created a Name from my Cad Program, Exported it as STL and then opened it in Replicator, Asved the GCode, then created the .x3G file. ... what I never picked up was the Dialog when creating the GCode, it had the Default of 80C for the Extruder Heads.
THANKS Everyone that tried to help me too, Much Appreciated
Ken
