Thread: Printer with budget $500
09-25-2014, 01:12 PM #1
- Sep 2014
- 6
thanks for advice
09-26-2014, 11:54 AM #2
- Sep 2014
Good luck with that, they seem to all be too elitist here to bother with anything under $20K.
09-26-2014, 01:18 PM #3
- Dec 2013
- Georgia
- 934
Printrbot has a few that are pretty close to your price point, and the Printrbot Simple Maker Edition is a kit that is $400, but has some, (and by that I mean a lot of) assembly required.
The downside to the Printrbot printers is the very small build envelope. If you don't mind assembling completely from scratch, the RepRap Mendel is almost exactly $500 to make unless you're going for premium materials.
In general printers that are currently on shelves will run you $800 to $2000 depending on the brand, and price does not equal quality. There are quite a number of Crowdfunding campaigns that promise printers in the sub-$500 range, but for the most part, they are a story that doesn't have a happy ending. (Printrbot was one of the very, very few Kickstarter budget printers that did everything right. and has succeeded for it, so it can be done.)
StlLooking, I have no idea where you're getting this kind of impression. Almost every printer that is even seriously considered around here for home use is in the sub-$4000 price range. Some printers you will be warned away from around here are the Phoenix 3D and the QU-BD printers. There are some other Crowdfunding campaigns that also get a bit of (sometimes deserved) derision and naysaying here as well, but not specifically for being cheap.
09-29-2014, 07:48 AM #4
I picked up my XYZ Davinci for under $600 with some extras on Amazon. Comes ready to print (for the most part) out of the box. I chose it over the printrbot for a few reasons,
1) Comes preassembled for the same price as the Printrbot preassembled, but does 8" cubes vs 4".
2) Ease of use, it's pretty much a beginners machine from what I can see and the software is pretty simple. Their tech support is pretty good, if not annoyingly so, if you do encounter issues.
3) It looks a helluva lot better on the shelf than the Printrbot. That's usually not a big deal, but when you're down to the bottom of your list of pros v cons, cosmetics do have their place.
One major downside is the filament comes in a proprietary cartridge. While it can be hacked to run off a spool, I have not yet. The quality and amount of filament you get is less than a similarly priced spool.
09-30-2014, 07:33 AM #5
- 349
8" cubes vs 4"
