Results 1 to 9 of 9
Thread: creator x stops printing
09-25-2014, 06:15 PM #8
Mate, I am one of those people that unfortunately just thinks of something and does it... like the other day im swapping my head over the old extruder to print flex .... the machine was on, fans spinning... I have swapped heads many times while its all hot and running, my screw driver clipped a fan and broke 2 blades... luckily I wear glasses or I'd be 'stevie wondering' my way around the printer now haha...
So yes, I don't disagree... turn machine off before messing with
re the Sd card failure, Yeah the point in which the job fails is pretty important, I am waiting for his reply to my other questions..
ie.
1. Does it happen on all prints, at a similar point? no matter what the model?
2. Does it happen to only one particular STL file?
i.e you said you got 4 good prints then it happened again, was it the same model that worked OK 4 times? or did you print something else then come back to it?
