Results 1 to 10 of 76
Thread: Auto Bed Leveling troubles
09-17-2014, 08:56 AM #1
What values do you have for these settings?
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {50*60, 50*60, 150, 0} // set the homing speeds (mm/min)
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,854.91} // default steps perunit for ultimaker {78.7402,78.7402,200*8/3,760*1.1}920
#define DEFAULT_MAX_FEEDRATE {250, 250, 2, 22} // (mm/sec)
09-17-2014, 01:11 PM #2
- Sep 2014
- Deer Park, TX
- 62
I changed the values to match yours.
When I attempts to move through the different axis, this is what happens.
+Z: endstop hit....no movement
-Z: step motors move a bit slower than normal
+X: endstop hit....no movement
-X: Slow movement
+Y: endstop hit...no movement
-Y: slow movement.
Would it be possible to just post your configuration.h file so I can go through line by line to see where mine has errors?
