04-21-2024, 05:12 AM #1
- Mar 2024
- 8
Hi all..
I have an Anycubic Photon Mono 2 and so far Ive only printed very small components/objects (around 5mm x 10mm in volumes of maybe 50) but many times the print fails or semi fails because it does not fully stick to the base, and half/part of it has unstuck during printing
I am using Anycubic 3d printer resin https://www.amazon.co.uk/dp/B07FY7DF...roduct_details
I want to print a much larger object which will be two solid blocks one with dimensions of (130mm x 50mm x 15mm) with 1mm holes through it, and another a little smaller (100mm x 30mm x 8mm), and so both will fit on base (143mm x 89mm)
Ive played around with settings but Im not sure if they are correct (see attached pics)
Can anyone please advise why its not sticking to base plate, and do I need to change some settings?
Thanks
legepe
04-22-2024, 01:20 PM #2
- Mar 2024
- 8
Hi again
Sorry for the above post.. It was obvious that I hadnt looked at the settings for the resin. I have now set them as advised to - Bottom Exposure: ~60s; Normal Exposure: ~8s but even with this I was still getting a similar problem! However, I have managed to get one out of three prints which stayed stuck to the base plate
I am trying to print a flat peice (see pic) with holes in it which are 0.8mm 1mm, 1.4mm & 1.8mm
This print though has srinkage which i am working on fixing through changing the dimensions of the holes using tinkercad before printing
is it normal for what I am trying to do to have the holes filled in with cured resin just on the surface and is there a solution to this
The other thing even though the print stayed stuck to the base plate it seems warped on the edges even though the holes are stright
I am just a newbie.. please !! anyone with any advice very much appreciated!
04-22-2024, 01:26 PM #3
- Mar 2024
- 8
06-19-2024, 02:02 PM #4
- Jun 2024
- 11
I have a Photon MonoX 6k. It may have something to do with suction coming off the FEP as it is a large profile part. You can play with the lift speed and distance and see if that helps. I am fairly new at this as well.
Help with fondant embossers
05-19-2025, 10:48 AM in Tips, Tricks and Tech Help
