Thread: A little help with first layer
02-28-2024, 03:32 AM #1
- Jan 2024
- 16
Oh, my z is -0.05. Anything less (as in closer to zero) and adhesion is less than aweful.
02-28-2024, 05:42 AM #2
- May 2020
- 623
From the photos it looks like you are using the smooth side of the PEI bed sheet, if so, try the rough side and re level the bed or use some glue stick if it's the smooth side.
Just a thought......there is an X-CF pro profile in ORCA slicer and also some calibration files to print.
I checked my 'e' steps and had to change them. If you check them for 100mm of filament and you are getting more or less than 100mm extruded send an email with the details to....
may@qd3dprinter.com
I did, and I was sent an update with the corrected 'e' steps.
Qidi doesn't do the usual G-code 'e' steps, so sending the usual modified G-code file to the eprom doesn't work.Last edited by Bikeracer2020; 02-28-2024 at 05:59 AM.
02-28-2024, 09:58 AM #3
- Jan 2024
- 16
Hmm,
Well it actually did worse that time on the rough side. You can see the two hole starts that popped off.
Yes, I do wipe with an alcohol soaked paper towel, and do a fast level EACH time. Please advise.
The first one I showed I let finish. I had to have one good one today. This one I had to cancel.Last edited by martinav; 02-28-2024 at 10:21 AM. Reason: more info
