03-14-2023, 05:34 PM #1
- Mar 2023
high temp thermistor/ thermocouple advice
Hey to all, I am new here and still fairly new to 3d printer although I have owned a delta printer since years.
Basically I bought one way to early in time and a crappy one too (geeetech g2s pro delta).
So i am rebuilding and upgrading it..
but i got stuck on the choice of thermistor / thermocouple.
As board I will be using a mks Robin Nano V3.1 which probably uses the standard 4.7k pull-up resistor.
Anyway, I am looking (for future use) to upgrade so it is high temp capable, so ofcourse this needs to included the thermocouple.
I have purchased (blindly) a K Type Thermokoppel (1M Hoge Temperatuur Sensor 0-600 degrees), but i am not sure if i can use that without a module (like MAX6675 type) on this board.
Also I wouldn't know how to use a module like this on my board if i would need to use it and to use a pt1000 i would need to upgrade the onboard resistor which i can't and again for a pt100 i'd need a board again.
So any advice on what to use,and more importantly how to connect this (properly) any thoughts on the topic would be very much appreciated.
Kind greats Matthieu
