Results 1 to 10 of 43
02-20-2023, 11:00 AM #1
- 47
Thank you so much for al your wonderful advice I will research alternate ways to "scan" an image Maybe search too for a new 3d printer that does vinyl will attempt to use unopened printer to test drive it Since I am getting into restoration of vintage equipment which contains little plastic gears, pulleys and idlers maybe it pays to invest in something better ,Question, in the code you were so nice to provide, can you add axle (stem) hole of 1.5mm all the way through?I guess the code you sent I incorporated into the supplied software and then print, should be exciting Thank youJ eff
