Thread: Gcode help
08-27-2014, 06:39 AM #1
- Jun 2014
- Burnley, UK
- 1,662
Gcode help
I am beginning to think that the Gcode interpreter in replicatorG is not a full implementation.
On my CNC machine if I want to do something periodically like blow swarf off the bed I can add loops and conditional branches. I can't work out any way to do this on the 3d printer.
If, for example, I wanted to wipe the head every 5 layers it should be something like this:
In start.gcode
#101 = 5 ;
In layer_change.gcode
WHILE [#101 GE 0] DO1
#101 = #101-1
END1
IF [#101 EQ 0]
#101 = 5
"WIPE HEAD gcode"
The problem is that no matter what I do it with, IF DO WHILE END all give errors as does declaring a variable with the #"variable" statement.
Are there any loop, decision making methods implemented?
Is it possible to read values back into your gcode. For example if I wanted to reduce my bed temperature by 5 degrees per layer is there a way to get current temperature and subtract 5 from it then use that to set the temperature?
It seems to me that this should be possible if the software is complete and for it to be really usable.Last edited by Mjolinor; 08-27-2014 at 07:26 AM.
05-17-2024, 12:15 PM in 3D Printer Parts, Filament & Materials
