Results 21 to 30 of 36
10-19-2014, 01:05 AM #1
- Sep 2014
- 27
Thank you very much for your reply!
Products Description:
The delta 3 d printer heating bed upgrade kits
List:
1:Heat the bed 1 PCS(Wire has good welding, welding thermal already)
2,The power of 250 w DC24V 1 PCS
3,Relay board 1 PCS
4,M3 * 30 screw 3PCS, spring 3PCS, 4PCS M3 nut
5,The M5 * 10 4 screw
10-19-2014, 01:06 AM #2
- Sep 2014
- 27
List:
3,Relay board 1 PCS
10-20-2014, 03:09 AM #3
- Sep 2014
- 27
Our heating bed heating time is 40S, it is fast, you deserve it, believe me!
10-25-2014, 04:05 AM #4
- Sep 2014
- 27
HE3D mini 3D printer, lovely!
Attention: This product is kit package ,need assemble .Thanks .
3d printer Motherboard: melzi main chip 1284 p
3d printer stepper motor A4982 chip
Output power: 24 v input AC110-220 - v
Print the most large area: 140 x140x110mm
Physical size: 260 x280x280mm
Printing material: ABS, PLA, 1.75 mm in diameter.
Building surface: PCB heating bed, aluminum mesa, in order to reduce the complexity of the assembly, to ensure parts deformation.
nozzle diameter:0.4mm (if you need 0.5mm, please left a message for us)
Precision standard: 0.1 mm
Resolution: 0.0125 mm
Construction speed: 1800 mm/min
Move speed: 1.2 mm/minute
Operation systerm support: Linux Mac windows7 or later XP
Printing software: Repetier Host or Pronterface
Deposition rate: 33 cm/hour
Movement: X and Y and Z axis low friction bushing, X, Y is linear bearing. All welded electronics and built-in microSD card slot for independent printing. Enhanced set, improve the X and Y shaft assembly is convenient Ultra-low print noise, let you print more quiet!
Contain all parts for assembly .
1, 1 pack hardware fittings
2, 5 NEMA14 stepper motors
3, heating bed 1 set of components
4, extrusion units 1 set
5, RP plastic parts 1 bag(total 42 piece. 2 metal coupling)
6, power supplier 1
7, 1 piece motherboard
Besides, we will give you 100g ABS , a set of special little tools and 1m high temperature tap as gifts . Thanks .
It is recommended that at the same time buy:
10-29-2014, 09:38 PM #5
- Sep 2014
- 27
Delta, increased the hot bed, more perfect!
heat up quickiy!work after 40 seconds,the temperature can be heated to 120℃
Attention:if you entered website from my AD,Please be sure to say "hi jo-jo", I well thank you very much, and I will give you a surprise.Thank you very much.
11-06-2014, 04:01 AM #6
How much shipping to Australia?
11-08-2014, 12:33 AM #7
- Sep 2014
- 27
Dear super moderators, complete the assembly of the delta 3 d printer, this is the way to transport to Australia and freight:
EMS:$140
DHL:$130
Fedex Rates:$130
If you need it, or have other needs, please contact me, I hope to receive your reply as soon as possible, thank you very much.
Best wishes to you!
jojo
if you entered website from the AD,Please be sure to say "hi jojo", I well thank you very much, and I will give you a surprise.Thank you very much.
HE3D
web:www.reprap.cn
Email:support@reprap.cn
skype:reprappro.cn
11-08-2014, 12:15 AM #8
- Sep 2014
- 27
Dear super moderator,
How are you?Please reply me, you will need to delta 3 d printer kit, in addition to plastic parts, right?Our delta now has heating bed, it is more perfect, if you still need?
I provide link for you, if you don't need it, please tell me, thank you! the best regards!
jojo
delta 3d printer kit: http://www.reprap.cn/he-3d-the-compl...-kit-p-85.html
heating bed : http://www.reprap.cn/dlt180the-delta...kits-p-88.html
HE3D
web:www.reprap.cn
skype:reprappro.cn
11-09-2014, 04:16 AM #9
Thanks, now if you answer the message I sent you we might be able to actually do something.
11-12-2014, 09:28 PM #10
- Sep 2014
- 27
because of the time difference between us, I can't reply you at once, if you have Skype, I would like to stay up late to wait for you!
HE3D
web:www.reprap.cn
skype:reprappro.cn
