Results 1 to 10 of 10
Thread: What 3d printer is this?
11-13-2021, 04:46 AM #1
- Dec 2017
- 12
Discovered not all Creality boards are the same, the one I bought will only work in an Ender printer with the Ender display. The one to buy is the Creality V4.2.7. Thanks to Amazon's return policy, I'm going to get out of making a stupid mistake.
This adds nothing fancy to the printer, just gets the machine whear it should have been when I received it. It will work with the Aquila display and is almost a direct replacement. The big issue is the mounting holes are not the same. Only one mounting screw lines up. My plan is to cut off the standoffs, drill new mounting holes and mount the board with new standoffs, this will keep the USB and card slot in the proper location.
After replacing the board you can load whatever firmware you want, OctoPrint will work as it should and of you want to add a touch probe it will work.
Voxelab should be ashamed for dumping these printers on the market. They should give everyone that bought the dreaded H32 some sort of rebate.
