Thread: Ender 3 v2 Gaps in print
09-07-2021, 09:23 AM #1
- Sep 2021
- 3
HelloMy ender 3 v2 worked perfectly. then i packed it away and took it on a plane back to the UK now all my prints have weird gaps in them. Please see the attached image.It is not the gcode as it is the same gcode as i was using before the move. This tells me it is something to do with the printer itself. Maybe something that got damaged on the flight.I have tried cleaning then replacing the nozzle. adjusting the belt tensions. even tried upgrading the firmware (although it worked fine before).Any ideas before i start spending money replacing parts? at least which part may be to blame.
09-07-2021, 04:37 PM #2
OK a Question?
In what country were you in before returning to the UK.
Is there a different voltage between the two countries, maybe a different line frequency example 50hz vs 60hz.
09-07-2021, 04:40 PM #3
09-07-2021, 04:42 PM #4
- Sep 2021
- 3
Thanks for the reply.
That is interesting. I had not thought about that. I was coming back from Vietnam.
Both 230v and 50hz. Interesting thought tho, thanks.
Do bed magnets deteriorate.
