Results 11 to 16 of 16
Thread: How do I draw this in 3d?
08-27-2021, 07:08 AM #11
- Aug 2021
- 6
I think I read it wrong and your wanting the sleeve to go over the nozzle then use a knife. You have to mind and use material thickness so your inside of your sleeve will be the outside of the nozzle. I see your tip has 14mm diameter at the top. if you have a 1mm wall then it will obviously be 12mm inside that then gets cut. Send me the dimensions that you want the finished nozzle to be.
08-27-2021, 10:25 AM #12
nice - but all you need is to cover the cone part - you don't need the base parts. All it's for is to cut the tip at the right level and then cut the v into it.
So the base of the screw on nozzle - not necessary.
Looks good though :-)
08-28-2021, 10:30 AM #13
- Aug 2021
I've made some more pics of the nozzles. The nozzle on the left is the standard silicone nozzle, the other ones are what I use. Currently I use the shortest one and cut it to somewhat the shape I need.What I want to make is some sort of shim that fits around the uncut nozzle and that helps me to make controlled and consistent cuts.If this works I plan to make a different one for the nozzle in the middle, with different cut guides for other glue jobs.
11-17-2021, 02:51 AM #14
- Nov 2021
I have long seen something like that.
12-19-2021, 03:24 AM #15
simply upload to your cloud and send a link and i will complete this.
04-25-2022, 02:06 AM #16
- Apr 2022
