Results 1 to 10 of 15
Thread: The Story of my NEO
08-11-2014, 04:26 AM #1
- Jul 2014
- Munich
- 45
Hi Eugene
Like I promised a few answares, I think I can help you in a few points.
1. Happens also with my plate I changed to a Macrolon (more flexible) one and put a new buildtack foil on it since this time perfect
but with the original its also possible but you need to be more carfuly bec the bulidtack foil hold the the printed part realy hard if printed to close to the printbed.
the solution is to adust the bed to the right position ( means the first layer should only pressed down a little bit its realy nearly a lay down not more) and only a small bending of the plate if one side is loosing conection use a tool to remove it.
2. You mean creasing at the point before the bowden ? if yes there is a update part (the black part now goes much closer to the transportation) please check if your Extruder Looks like this picture (you need to remove the 4 screws to see it )
if not please tell me.
3, sound like yes a fan could be a soulution.
4. The default Profile is for the GRRF Filament there you get good results with it ( I personaly print around 5 ° colder) with other Filament you need to find the right temperature for it.
6. Slicer specialy the new ones are full of bugs I still use a old one ,but more and more I use Simplyfy3D specialy the support is great.
7. Does yours Move ? My one most times are ok so long I put the plate on the same way back i put it out but also than I need to readjust it only bit.
About the fan Installation, you found already the 2 on the bottom if you want a controlled one you can use the connector on the board ( he is activated in the firmware) theright conetor on the printboard is marked.
BUT you need to open the backplate I didnt know what happens with the warrenty if you open ( I did it bec printer was working the first days and I changed also a few other things so I didnt have warrenty anymore)
if you remove the side panel please be realy careful with the usb conector !
I can ask GRRF about but that will need a bit time ( visiting USA for Holiday so until end of the month can not talk with GRRF)
And I can tell you more A few members from the GRRF-Forum Member were working on a great fan holder ( I can place a picture here this afternoon munich time) he stillnot fully finished but a few people already testing and working with and on it.
I can send you the file if you want or you waiting a bit bec there is a 2 parts model nearly finished who is much easier to assemble.
all for the moment I will prepare a few pictures this afternoon let me know if you want some more detailed informations.
br
Thomas
upadte you can see the fan holder with the ring around the hotend on the pictures of the first post.Last edited by Luchador; 08-11-2014 at 09:17 AM.
