Hello,
Thank you for sharing your experience!
I've bought NEO 3d month ago and still trying to solve problems. I am new to the 3d printing so it takes time to figure out how to make prints better.
So far
1. I have destroyed plastic plate for the printbed. Carbon film has teared off after a few prints and I had to make another plate from plexiglass and it works quite well now.
2. My extruder sometimes creasing the filament and I am waiting for the new extruder from German Reprap.
3. Quite often I can find brown dots or even blobs on the printed models. I was trying to figure out what's happening and it seems that it caused by dirty nozzle. The nozzle becomes dirty when material twisting on the corners. Yesterday I tried to blow to the model with hair dryer in cold mode and I don't see material twisting. Now I am looking for a solution of installing a fan.
4. Default temperature settings are 210 for the first layer and 210 for other layers, but after I've printed a few models for calibration I found out that optimal temperature for other layers is 185.
5. Playing with layer height, the optimal one for me is 0.15mm and first layer is 0.2mm.
6. Also my version of Slic3r has very interesting bug in settings. Speed setting named "Bridges" actually controls speed of printing outer walls :-\
7. And the last thing... is there any solution for fixing the printbed so it won't be necessary to calibrate it before each print?
game cam
Could you, please, give more details about fan installation?
I have searched through thingiverse but cannot find the correct fan holder and also it is unclear where to connect it? Does NEO 3d have pins for it?
Thank you in advance!
Best regards
