Results 11 to 16 of 16
Thread: General questions from a newbie
05-26-2021, 06:27 AM #11
yeah the anycubc printers are a pretty decent design.
The colourants used in printer filament makes a real difference to how well they print.
red is best, white is next best and black is pretty good.
Blue, not bad.
Orange - excellent.
Yellow - can be difficult, it's also the hardest colour filament for manufacturers to make - they hate it lol
Grey/silver filaments are also very good to print with.
Pla with wood is really stringy, tpu (flexible filaments) are trickier to print than non-flexibles. Red is definitely the easiest there.
Clear/transparent filaments tend to be more stringy than coloured ones. But also stronger and a little more flexible.
Just avoid abs :-)
The anycubic will print all the regular filaments - no problem.
Pet-g totally fine for a cup holder in germany :-)
I have a pet-g sink strainer that gets boiling watre poured over it regularly.
No signs of temperature effects at all.
Pretty impressive.
05-26-2021, 08:28 AM #12
- May 2021
- 6
Thanks
Found another printer "Artillery Genius" your opinions?
05-27-2021, 02:00 AM #13
- Apr 2021
- 186
Good option. I'd rate it above the ender 3.
05-27-2021, 09:37 AM #14
Hmm, well the artillery genius does have dual z axis.
But it's got a bowden extruder - and a really narrow bed mounting setup.
So you're going to have bed levelling issues.
But yeah - better than an ender 3 lol
if you want to go the ender/creality route - this is proibably the least bad machine they make: https://www.amazon.co.uk/Creality3D-...strial&sr=1-28
It could do with converting to a direct drive extrduer - but other than that it';s a solid frame and a decent cartesian setup.
https://www.amazon.co.uk/Sovol-Extru...strial&sr=1-56
the sovol's not a bad machine. D=ual z-axis and direct drive extruder
https://www.amazon.co.uk/Sovol-All-M..._t1_B07TNP914D
that's the sovol 02 - I;m not sure about the 2 in 1 out extruder. probablt works fine with just the one filament though on a 1 in 1 out basis.
So bearing that in mind i'd pick it over the 01 as most everything else has been upgraded.
05-27-2021, 09:43 AM #15
https://www.amazon.co.uk/TENLOG-Hand...strial&sr=1-93
worth a look. Dual idex extrduers, linear rails - just a nice set of quality components.
05-27-2021, 04:06 PM #16
- Apr 2021
- 186
Artillery genius is direct drive.
