Results 211 to 220 of 321
Thread: Flashforge 3D Creator forum.
06-18-2015, 03:04 PM #211
- Jun 2015
- 6
06-18-2015, 03:49 PM #212
- Jun 2015
- 6
06-18-2015, 04:29 PM #213
- Jun 2015
- 6
06-18-2015, 04:44 PM #214
- Burnley, UK
- 1,662
Load filament with it in bits and watch the stepper doing whatever it does. If that turns smoothly then it is down to heaters and/or plastic but if that dithers and vibrates it is a broken wire or driver. Swap the plugs if you have two extruders see if the other motor is smooth.
Stepper motors never break unless you pull them apart, then they never work again.
06-18-2015, 05:43 PM #215
- Jun 2015
- 6
if i try to load filament into it i have to force it into the extruder, the head judders like mad and the filament will extrude bumpy. if i just put a piece of filament into the extruder it'll jiggle up and down as the feeder is trying to push the filament out, not feed it in.
i'm using the left extruder atm to print while i search answers. the left extruders working fine. just this right one has played up for past couple days til its now just not feeding filament through
06-18-2015, 06:18 PM #216
- Burnley, UK
- 1,662
Take the extruder off the stepper motor and load filament on the menu, watch the stepper motor is what I meant.
06-19-2015, 01:20 PM #217
- Jun 2015
- 6
06-19-2015, 01:39 PM #218
- Burnley, UK
- 1,662
if it is running the wrong way and not smoothly then it is a broken wire or a faulty stepper driver board.
06-20-2015, 11:43 AM #219
- Jun 2015
- 6
Well folks a bit of an update. stripped the extruder right back and tried to feed filament into it as Mjolinor suggested. the lil motorized driver part just clicks back n forth slightly. swapped the power cable round from the left extruder to the 'broken' right extruder and it goes perfectly. swapped the right power cable to the left extruder and that does the same slight back n forth thats been the issue.
i've checked the wire ends and i can't see any broken wires, also the printer is only 2months old at most so i'm asuming its a Faulty stepper driver board as Mjolinor suggests. next question.... how easy is it to fix or is it something thats gonna require it to go back to the supplier to exchange for me? (still under warranty)Last edited by Laughlyn; 06-20-2015 at 01:12 PM.
06-21-2015, 09:55 PM #220
- Mar 2015
Thank you for taking you time to write this up. It's been a big help
