Results 1 to 10 of 16
Thread: When to use 'Support' option?
04-06-2021, 04:50 PM #8
- Mar 2021
- 63
Thanks CA. I managed to cleanly remove the main Cura support around the rim. But not the much smaller support underneath the little pull tag on top, which broke. Luckily enough left to ream out a shallow hole and glue it with superglue.
I realised afterwards, reading up on Support in general, that I should have done it exactly as you described.But I’ve since decided that if I print another for the same purpose I’ll simply enlarge the lower cylinder and hollow it out, effectively turning the ‘rim’ into a ‘lip’, and hence eliminating the need for support. The pull tag could also probably do without support by being a single tapered cylinder.
Or I could just buy a heating pad!Last edited by terrypin; 04-07-2021 at 01:20 AM.
