  1. #1
    FS: Markforged Mark Two 3D Printer
    I am putting this up for sale a Markforged Mark Two 3D Printer for sale, everything looks clean and is in excellent condition. This is the best-in-class professional carbon fiber 3D printer – built around the Continuous Fiber Reinforcement (CFR) process to reliably produce strong parts for you. No issues whatsoever with this printer as it has always been handled professionally and maintained properly, it is ready to be used. The Mark Two has a 2nd-generation fiber reinforcement system that enables you to lay down continuous fiber into parts. Only Markforged composite printers are capable of printing continuous fiber reinforced parts, which can be as strong as machined aluminum.It’s built around an aluminum unibody frame that delivers high accuracy and repeatability. A hardened extrusion system enables the Mark Two to print Onyx a micro carbon fiber filled nylon filament that destroys traditional extrusion systems reliably over thousands of print hours. The machine is built to be easy to operate and maintain from easy-to-reach wear components (like nozzles and feed tubes) to usability focused features like the print bed, which can be removed and replaced with 10 µm repeatability.It is the most reliable, easiest-to-use machine, delivering perfect prints every time. More items included with the printer are listed below:800cc Onyx Filament Spool - 1 Desktop Series Plastic Load Tube 3 PackDesktop Series Plastic Bowden TubeMarkforged DryboxPurple Elmers Glue50cc Carbon Fiber CFF Spool - 2 50cc Kevlar CFF Spool - 150cc Fiberglass CFF Spool - 150cc HSHT Fiberglass CFF Spool - 1Extra Fiber Nozzles - 3Extra Plastic Nozzles - 3Part Scrapper - 1L-Keys & Dry Box PlugMarkforged Torque Driver - 1Fiber Nozzle PTFE Tubes - 3Small Wire Brush for cleaning the Nozzles - 1 Asking Price: USD$9,500If you are interested kindly send me a message,oi700840 at gmail dot com dot comThanks for looking..!!
  2. #2
    This is still available for sale.
