Thread: Print Shifting Problem
02-03-2021, 10:53 AM #1
- Jan 2021
- 2
I know there can be multiple issues that can cause print shifting, but I have checked all of the basics such as belt tensions, pulley gears, print head, and glass bed movement, which where all ok. The only thing I did not check was the filament spool. I did not because this was printed from a brand new roll. Is it possible that the filament was wound wrong or would this even cause something like this to happen?
Weird thing is as you will see from the pics is that it started relatively low from the base and the top tubes above the shifting printed perfectly. The piece on the right in the pic is the right side of the case, it was printed before the one on the left separetely and printed perfect as well.
Any feedback would be greatly appreciated on this one!
Printer Specs:
Ender 3 Pro with 32bit Board V4.2.2
BL Touch Model 3.1
Micro Swiss Hot End
PrinterMods MDD
Creality Glass Bed
FIRMWARE is the latest from daily builds at https://marlin.crc.id.au/
07-21-2021, 01:56 AM #2
- Jun 2021
- 4
Linear rail
Hi. It might be that the linear rail is too tight. Try to slightly loosen (quarter turn) the screws holding the linear rails in. It fixed the issue for me. For more 3D printing help, you can look at my blog.
07-21-2021, 03:46 AM #3
Is there some abnormal vibration during printing, which is causing the printing problem?
07-27-2021, 08:11 PM #4
- Jul 2021
