Results 1 to 10 of 12
02-01-2021, 10:15 AM #4
I assumed you would post like you did if you had any questions.
Files I attached allow you to use a different slicer to slice the models for your Davinci Jnr 1.0. 1st unzip the files to a folder to allow access.
I would suggest starting by download Prusaslicer 2.3.0 an install the program.
Start the Prusaslicer 2.3.0. Select File > Import > Import Config : locate and select Dav_VanciI_1.0_AIO.ini PrusaSlicer is ready to select a model ans slice for Dav_VanciI.
This should allow you to slice a model an 3D Print with your Davinci Jnr 1.0.
