01-06-2021, 10:46 PM #1
- Jan 2021
- Dubai
Tips for securing load on a trailer safely
It is important to make sure that you don’t overload your trailer as it can affect your breaking rate simultaneously affecting traffic safety. It could cause damage to road surface. It is important to adhere to the maximum weight that can be carried on the trailer. When driving up ramps, always keep the heaviest end of the equipment uphill. One should have the appropriate type and amount of securing equipment. The key is to consider what kind of hauling equipment is important for the freight you are hauling. Ideally your tie-downs should have a combined strength of at least 50% of your load. Ensure tie-downs are properly rated for the load they are meant to secure. It is crucial to inspect them for any wear and tear, and replace when worn or damaged. Tie-downs are supposed to be secured lower on the trailer, and not close to the top rails. They should be secured in a manner that prevents it from becoming loose, opening, unfastening or releasing while in transit. If you are looking for the right partner for trailer lashing services in Dubai, then reach out to Ceekay. They are one of the prominent
