Results 1 to 9 of 9
12-05-2020, 08:54 AM #7
I agree with Roberts in this case. If it worked before and now failing on all models, you need to disassemble the extruder and take a look inside, its easy.
1.) Check the feeder wheel so its clean.
2.) Inspect the silicon pipe so its not damaged.
3.) Replace the nozzle.
If that doesn't work then its the step motor that gives up after a while of printing.
