Results 1 to 10 of 13
  1. #1
    Quote Originally Posted by Roberts_Clif View Post
    Measure the distance between the smooth rods at 3 locations MIN, Center and MAX on the X-Axis to See where they are not parallel. Larger or Smaller gap between the smooth rods.
    I don't have any micro level way of measuring accurately but using a ruler and by eye it would appear the rods are evenly spaced, the same measurements all along the steel rods.
  2. #2
    Jun 2017
    Location
    Washington State, USA
    Then I proposse another way to get your 3D Printer working.
    Great Bearing Cleaning video
    https://www.youtube.com/watch?v=KQHugGSQd5M
  3. #3
    Then I proposse another way to get your 3D Printer working.Great Bearing Cleaning videohttps://www.youtube.com/watch?v=KQHugGSQd5M
    Aha ok I'm not surprised by this suggestion. Something I forgot to mention is that the bearings also make various horrible sounds whenever the printer moves left of the midway point along the x axis. You could very well be onto something here. I'll have to get one of these ultrasonic cleaner things though. Will any work? they seem to vary in price quite a bit.Ughhh not looking forward to removing the bearings again, its a big job.... but needs must.
  4. #4
    Jun 2017
    Location
    Quote Originally Posted by Impytus View Post
    You can clean the bearing in any solvent or using plain alcohol, alcohol is what I use to clean my bearings in a shallow dish.
    I also use canned solvent or de-greaser.
  5. #5
    So I don't need an ultrasonic cleaner?
  6. #6
    Jun 2017
    Location
    No!!!
    Though they are quite handy on some occasions it is a purchase that is required.
    You can use a splashing motion or fill a Spray bottle and get the bearing clean.
    I 3D Print Fidget Spinners for Halloween every year and use roller skate bearings.
    These bearings are packed with grease and fidgets spin faster with no grease.
