Results 1 to 10 of 12
11-16-2020, 02:02 AM #1
- Nov 2020
- 23
3D printed bicycle with working chain
Hi all,
Check out my 3d printed bike.
https://youtu.be/Tw5x-3CF8dYLast edited by 3dprintall; 11-16-2020 at 02:09 AM.
11-17-2020, 08:22 AM #2
very neat indeed !
Why ?
Was it for an actual project ? or just for the hell of it ?
11-17-2020, 10:54 AM #3
- Nov 2020
- 23
11-17-2020, 02:38 PM #4
Wow!!!
Would like to 3D Print one like that for myself...
Why?
1. Because I do not have one.
2. To see if it could be 3D Printed on My 3D PRinter.
3. To 3D Print a Chain for a working 3D Model
11-17-2020, 03:13 PM #5
- Nov 2020
- 23
haha thanks for the comment, you got some fair points there!
You should be able to find some working non bike models with chain on Thingiverse I assume (Not sure if you would be able to find a bike model with working chain, but I am sure there are 3D model bikes (not on thingiverse) with chain which you just have to modify to be able to 3d print)
Right now I am planning multiple things for my Youtube such as giving away the files after reaching certain goals and giving away the physical model and such.
Stay tuned and please be patient as I am only doing this projects and youtube during my spare time.
11-17-2020, 07:09 PM #6
I went looking after seeing your model could not find anything near as good.
If you post your You-Tube Channel, so we can keep up to date when you get it started...
I can help you along by re-posting it to four other 3D Printer forum's if you would like...Last edited by Roberts_Clif; 11-17-2020 at 07:17 PM.
11-17-2020, 07:59 PM #7
- Nov 2020
- 23
Here is my Youtube channel: https://www.youtube.com/channel/UCnU...MXiwLs37_2tpyA Thanks for your kindness.
11-18-2020, 02:41 PM #8
- Nov 2020
- 23
@Roberts_Clif I was trying to send you some DM however it says you need to free up some space in your mailbox as it's exceeded.
11-18-2020, 03:41 PM #9
11-19-2020, 10:22 AM #10I can help you along by re-posting it to four other 3D Printer forum's if you would like...
can't believe you're seeing other forums behind our back !
Just, devastated :-(
Chain wise I designed a cable chain that would certainly print small enough to work as a model bike chain.
As long as you get a good solid connection between the links, it's pretty easy to do.
