Results 1 to 10 of 36
Thread: i need help badly
10-23-2020, 06:48 PM #1
Post the Problems you are having the forum and I will help you get it printing.
10-23-2020, 07:24 PM #2
- Aug 2020
- 29
Thx's so much i just replaced a part i am going to test it tommrow i mixed up two wires and then i will tell you the probelms if there are any
But the probllems i was having were layers not sticking together not sticking to print board and when layers did stick layer shifting
10-24-2020, 06:41 AM #3
As this is a Ender3 with layer problems I would guess that the XYZ axis may need adjusting.
Layer shifting could be caused by the XY Axis not having a smooth travel path most likely the Eccentric nuts are not correctly adjusted.
The Z-Axis problems could be related to several things including the slicing process.
When you again post with your current problems we will continue with suggestions.
10-28-2020, 08:13 PM #4
- Aug 2020
- 29
so i swapped the wireds i mixed up and the hot end heated up to 350 not the 220 i told it to (at least thats what the screen said) i then swapped them back and got the same thing. I just bought a new hot end becasue it looked like the plastic never heated up enough but now i dont know what is wrong and why it is saying 350. also the filament is not comig out. now the plastic not looking like it was heating up enough may have been the filament (i have solutech gray and blue) i dont know if i should put the old hot end backing since i know it works but telll me what you think i should do
11-11-2020, 11:54 PM #5
- Nov 2020
Check the XYZ axis
