Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
  1. #11
    Jun 2017
    Location
    Washington State, USA
    Sounds good.
    Let's start by talking about which firmware you have loaded.
    Ender 3 Firmware + Source Code + SD Files + BL Touch
    or
    Ender 3 Pro Firmware + Source Code + SD Files + BL Touch
    or Other.
  2. #12
    i have the first firmware
  3. #13
    Jun 2017
    Location
    When you first turn on 3D Printer what temperature reading do you have for your Hot-end and Hot-Bed.
  4. #14
    357 for hot end 22 for bed
  5. #15
    Jun 2017
    Location
    Thermister is shorted with a reading 310 °C or higher.
    I would suspect that the Thermister is shorted unplug and measure the resistance of the thermister at room temperature Post resistance.
    With Hot-end Thermister unplugged from controller board again turn on 3D Printer and post reading.
  6. #16
    so i lossened the bolt that was holding the thermistor and plugged it back in and it is reading 26 also it is putting out filament now
  7. #17
    the filament did not look very melted though
  8. #18
    Jun 2017
    Location
    Quote Originally Posted by crazymonke42 View Post
    so i loosened the bolt that was holding the thermistor and plugged it back in and it is reading 26 also it is putting out filament now
    Is this a different filament that you have never used before?
    Which filament are you using?
    How old is the filament?
    How was the Filament stored?
    What temperature was the Hot-End set?
  9. #19
    i have only had one filament it is solutech it is around a year old and was stored on the printer the hot end was set to 220
  10. #20
    Jun 2017
    Location
    Then if it does not look very melted it must not be PLA what filament type are you printing with.
    Have you tried to print a Temp Tower to determine what temperature it print best at.
