Quote Originally Posted by jamcultur View Post
Small objects can be printed directly on the platform of a resin printer, big pieces cannot. If you expose the first layer for a shorter time, it can detach during printing and ruin the print. FDM printers have excellent XY resolution, better than many resin printers. Resin printers have better Z resolution, but if you are printing flat objects, why does Z resolution matter?
Thank you for the information! my object will be 3.5 cm in diameter and 0.5 mm in thickness. I thought fdm printers would not print small details. If the DLP printer has an accuracy of 0.05mm, I do not know if such small elements are possible for FDM, such an ornament is not only straight lines. I will try to print to a DLP platform. when it comes to detaching from the platform i noticed that it takes a lot of force, won't it break?
