Results 131 to 140 of 174
Thread: My First CoreXY
09-21-2021, 01:42 PM #131
toes not so much - but inquisitive noses. probably :-)
It's a bright thing at cat head level, with slightly moving bits of the picture.
All custom made to attract a curious animals attention.
And midway through a 40 hour print.....
Were you to start making things, the kids might get re-interested lol ;-)
Also by kid level i meant, balls, feet, skateboards, abandoned bags, jackets etc.
10-25-2021, 03:33 PM #132
10-25-2021, 03:40 PM #133
Yes! Finally. It is here. The BTT Octopus Pro..
This board has a few notable improvements over the Octopus. It can support 60v power to the stepper motors. It also comes in 2 flavors. One with a slightly faster processor with a little less flash size and one with a slightly slower processor but 2x the flash size. The difference in speed is small 180mhz vs 168mhz. 12mhz difference for 2x or half as much flash size. We should be more focused on choosing the right flash size in selecting this board.
This project took a step backwards as I removed the mainboard I was half way into wiring to use as a replacement for my IDEX. Now we can get back underway. Hopefully we will see the brightest Neo Pixel lights, yet. Out of my rigs, anyways.
10-25-2021, 11:10 PM #134
Sooooooo, Here's a thing. Marlin 2.0.9.1 does not seem to support the BTT Octopus Pro. How about that.
The specific Pro I got doesn't even have the same processor as the Octopus and so I couldn't just use that.
Also there is no option to setup the Pro as the default envs in platformio.ini Or to select it from the drop down menu on the left column when clicking on the alien head. It just ain't there.
And so I will finish the wiring but I fear my quad Z coreXY project wont be able to run until after the next Marlin release. Which shouldn't be long, I am sure.
10-26-2021, 01:13 AM #135
- Apr 2021
- 186
2.0.9.2 has fixes for the octopus. Might be enough to get the Pro working. I haven't had a look at what is fixed though.
https://github.com/MarlinFirmware/Marlin/releases
Edit: Nevermind. Doesn't look like it's enough.
Edit 2: Bugfix has support for Octopus Pro - https://github.com/MarlinFirmware/Ma...c/pins/stm32f4Last edited by Martin_au; 10-26-2021 at 01:34 AM.
10-26-2021, 02:28 AM #136
10-26-2021, 09:34 AM #137
so maybe time to look at reprap firmware -
isn't that one reason for the larger memory size on the new
board ?
10-28-2021, 12:51 AM #138
- Apr 2021
- 186
Just had another look. Looks like there is support for the STM32F429ZGT6, using the same pins as the old Octo board. Check out https://github.com/MarlinFirmware/Marlin/pull/23008
It's not specifically mentioned in the stm32f4 folder, but is referenced in pins.h, where it sets up an environment for the F429 version.
10-28-2021, 12:43 PM #139
Ya if you could believe a moderator in the Marlin F.B. group posted a screenshot of that and when I asked the MODERATOR where he found that the only response I got was his ass. Awesome F.B. group that should make anyone else want to explore Klipper or Octoprint. TY and I will look for it. Also why are you saying 2.0.9.2? There was 2.0.8.2 then 2.0.9.1. Unless you know something else I don't? I am not calling you out but asking for clarification? It does make sense that there would need to be a new version after the mainboards release.
10-28-2021, 12:45 PM #140
