Results 1 to 10 of 10
09-15-2020, 03:31 PM #1
I was actually thinking of the stepper drivers and chipset on the board overheating.
Never actually seen the innards of a wasp delta - seen the machines, but not taken one apart.
But as far as I rmemnber all the electronics are housed in the base and it's sealed, so with really long prints the heat will build.
Unless I'm thinking of a different make - but there aren;t that many companies making really big deltas - so I've probably got the right ones :-)
a 10 day print !
What are you making !?
Okay this is the printer in question:
So probably not heat build up - there should be ample room in the base for proper heat dissipation.
That is one big beast !
Reminds me - I've got about about 90% of the bits for a 350x1000mm delta in various places in my workshop. Really need to find the time and inclination to finish building it :-)
OR - work out how big a corexy I could make using the same 30x30 extrusion. Hmmmm......
Anyway i Digress.
With a printer like that the manufacturers really should give you decent support. Cheap it ain't.Last edited by curious aardvark; 09-15-2020 at 04:23 PM.
