Results 1 to 10 of 50
07-29-2020, 09:18 AM #1
- Oct 2016
- 184
Sure, here's what I'm using in S3D. Mostly nothing specific to multi-material printing, only the comment tags to mark start and end scripts, for filaswitch usage.
Start gcode
Code:; START SCRIPT START M83 ; extruder relative mode G10 P0 R[extruder0_temperature] S[extruder0_temperature]; set extruder temp G10 P1 R[extruder0_temperature] S[extruder0_temperature]; set extruder temp G10 P2 R[extruder0_temperature] S[extruder0_temperature]; set extruder temp G10 P3 R[extruder0_temperature] S[extruder0_temperature]; set extruder temp G10 P4 R[extruder0_temperature] S[extruder0_temperature]; set extruder temp G10 P5 R[extruder0_temperature] S[extruder0_temperature]; set extruder temp M190 S[bed0_temperature] ; wait for bed temp G28 ; home M116 ; wait all temps M572 D0:1 S0.0 ; disable pressure advance ; START SCRIPT END
Code:; END SCRIPT START G4 ; wait G91; relative positioning G1 E-3.2 F2000 G10 P0 R0 S0 ; cool down G10 P1 R0 S0 ; cool down G10 P2 R0 S0 ; cool down G10 P3 R0 S0 ; cool down G10 P4 R0 S0 ; cool down G10 P5 R0 S0 ; cool down M140 S0 ; turn off heatbed M107 ; turn off fan G1 Z5 F1500 G90 ; absolute positioning G1 X0 Y300; home X axis M84 ; disable motors ; END SCRIPT END
This is the actual tool change gcode that is added by filaswitch and saved to a new file. This replaces every Tx command in the S3D gcode file.
Code:; PURGE START G1 Z4.0000 F960; z-hop G1 X204 Y10 F10000; move to purge bucket G1 X204 Y0 F10000; move to purge bucket G10 P0 R190 S190 G10 P4 R190 S190 M116 P4 G1 E10.0000 F540; prepurge/ramming G1 E-25.0000 F540; rapid retract G4 P3500.0; cooling period G1 E20.0000 F1500; long retract G1 E-35.0000 F1500; long retract G1 E-155.0000 F2000; long retract G1 E-5.0000 F1500; long retract T4; change tool G1 E5.0000 F500; feed G1 E165.0000 F2000; feed G1 E20.0000 F1500; feed G1 E5.0000 F300; feed G1 E74.9381 F153; purge G1 E10.0000 F80; slow purge G10 P4 R205 S205 G10 P0 R205 S205 G4 P3000; ooze pause G1 E-5.5000 F2100; retract G90; absolute positioning G1 X249 Y0 F5000; move from purge bucket G1 X210 Y0 F5000; move from purge bucket G1 X249 Y0 F5000; move from purge bucket G1 X210 Y0 F5000; move from purge bucket G1 X249 Y0 F5000; move from purge bucket G1 X249 Y20 F5000; move from purge bucket G1 X204 Y20 F5000; move from purge bucket M83; relative E G92 E0; reset extruder position ; PURGE END
