04-06-2020, 08:23 PM #1
- Mar 2020
- Ceciltucky
- 12
Help Plz - Tronxy X5SA Pro - The need for speed!
So I printed this calibration cube and it took 40 mins! It's only a 2cm cube that Cura estimated would take 18 mins.What's in the world is going on? Below is a pic of the recommended settings and the cube..
What settings should I be looking at to change this? Or is it a problem that I need to change in the firmware?
40mins.JPGLast edited by crabjoe; 04-06-2020 at 08:39 PM.
04-08-2020, 11:09 AM #2
- Apr 2020
Hey! check you don't have any Post processing scripts run, before you slice you'll see an icon like the one below to the left of the "slice" button, i had this issue where it would change it to 15% speed at a certain layer, other than that check your movement speeds, although Cura should account for that in the time of the print. That's why the only thing i can think of is a post-processing error. Another thing you can try is if you have a speed adjustment on the printer screen, when it moves really slowly try turning it up to a different speed then back down to 100%, I've found this can also over ride the post processing options. Annotation 2020-04-08 120637.png
Best of luck! hope this helps!
