Results 1 to 9 of 9
Thread: Help fixing mirrored prints
04-06-2020, 03:46 PM #1
If home is Left Front then X-Axis end stop is an max, Y-Axis is at min
From what you posted I believe all you have to do is.
// Direction of end-stops when homing; 1=MAX, -1=MIN
#define X_HOME_DIR 1
This would correct a left to right mirroring.
04-06-2020, 05:23 PM #2
- Apr 2020
I thought that would be the right thing to do as well, but that creates an error in sanitycheck.h SanityCheck.h:1154:6: error: #error "Enable USE_XMAX_PLUG when homing X to MAX." #error "Enable USE_XMAX_PLUG when homing X to MAX." ^exit status 1#error "Enable USE_XMAX_PLUG when homing X to MAX."
04-06-2020, 06:27 PM #3
Does Folgertech have a Marlin Configuration.h file
Post your Entire Marlin to a share like Google Drive post the lnik here will take a look.
04-06-2020, 07:12 PM #4
- Apr 2020
Yes it has that file type. That is where I go to try to tinker. I uploaded the code and shared the link. I also uploaded a picture of the printer to show where things are and the 0,0,0 when it homes.https://drive.google.com/drive/folde...dX?usp=sharing
04-08-2020, 06:55 AM #5
I Believe this line should be
04-08-2020, 11:47 AM #6
- Apr 2020
changed -1 to a 1 there and then it just moves away from the endstop for a split second and stops.
I tried tinkering with the X_MAX_ENDSTOP_INVERTING and X_MIN_ENDSTOP_INVERTING and that makes it move, but tries to keep going even when hitting the endstop.
