Results 1 to 10 of 11
Thread: Pla/pla+ question
03-26-2020, 08:52 AM #5
why can't you print with flexibles ?
You have a direct drive extruder - that's the most important thing. Most flexibles print under 240c - so no issue with hotend.
They all also print best on unheated printbeds - well I always use an unheated bed anyway :-)
Just remember you have to go SLOOOOWWWW.
maximum 30mm/s and generally better to run at 20mm/s.
Retractions around 1.2mm at 30mm/s
You have to do everything slowly as the filament deforms easily, changing the diameter and effectiing the feedrate.
But there is no actual reason for not using it.
