  1. #1
    Flashprint issues
    Hi Guys,I am considering buying a flashforge Adventurer 3, I have downloaded Flashprint and have imported a .stl model of a house which when I prepare it for printing the doors and windows are missing, im guessing they are too thin to print??is there a setting that will enable them to print? I want the internal of the house hollowmany thanks in advance.
  2. #2
    Jul 2014
    well it dependrs how thin they are.
    if they are thinner than the nozzle width - then they won't appear in the sliced model.
    If you can't edit the model then you could change the nozzle for a smaller diameter. 20 0.3 or 0.35 instead of 0.4
    Had a look through flashprint and I can't see any option for nozzle diameter. The closest I can find is 'path width'.
    Adjust that and resclie the model - if the window and doors appear - then that's what's causing it.
  3. #3
    Many thanks for that, have decided on an Artillery Sidewinder instead because of the printing size.
    so will be using Cura.
    is there a specific setting there? that will make windows show up.
    many thanks.
  4. #4
    Jul 2014
    forget cura use prusaslicer.
    Considerably more user friendly and designed for i3's whereas cura is designed for, well nobody lol
    It's horrible :-)
  5. #5
    I would also prefer Prusa Slicer - but unfortunately I can't get it to work with my Adventurer 3
