Results 1 to 10 of 14
03-10-2020, 06:54 PM #1
- Mar 2020
Well I don't know if I should let the extruder consume all the filament or leave a bit hanging out then have the printer pause and I manually remove the extra and insert the next filament?
I just want to prevent the printer running out of filament and continuing the print without filament or stopping there and burning the top layer. Qidi says you can't add stuff to their mobo or modify the code, so I guess il have to either have a wifi sensor send me a warning or I mount a wifi cam to monitor the print and spot when the spool is about to empty and manually pause the print.
I'm new to 3d printing so help is appreciated
03-10-2020, 07:29 PM #2
- Mar 2020
- Australia
I wouldn't worry too much about filament runnout unless you are using scraps. A full roll will last you many prints and if for some reason you are doing extraordinarily large prints most slicer software will give you not only the time it will take to print but how many meters of filament the print will use.
Given that you have asked qidi about the modifying the motherboard and/or code, I would gather you have some knowledge with electronics. In this case, if you still need this feature, it would not be very difficult to set up a small limit switch that is activated by the presence of the filament at the entry to the extruder. When the filament runs out the limit switch will change state sounding an alarm or stop the print.
Either way I believe it's a none issue. I've had a QIDI xmax for about 3 months and have yet to use a whole role of filament
03-10-2020, 07:45 PM #3
- Mar 2020
What's the best way to manage end of rolls though? Is there an option in the panel to manually advance the last feet or so of filament through the extruder to consume it so it doesn't clog, or is it better to pause the printer and pull on the filament (or reverse the motor it if there's such option)?
03-10-2020, 10:00 PM #4
- Mar 2020
- Australia
Speaking for the xmax only but it's safe to assume all printers are the same, there's an option to remove or change filaments. It heats the extruder up to your desired temperature and then you select if you want it to feed or retract. You can even pause a print and change filament half way through a print.
The instruction manual for whichever printer you want should be downloadable so you can see how it's done. To extract wait for the head to heat up, hit retract while pulling on the filament and it whips right out
03-10-2020, 10:20 PM #5
- Mar 2020
Ok thats good to hear. I'm looking for either the X-mas or X-plus, so knowing what you just said I don't see the point of a runout sensor. A good planification will avoid this issue.
Are you satisfied with your x-max? Iv'e heard plenty of good reviews but having another independent review would be nice. What are the cons that you've experienced so far with it if I may?
