Thread: Ender 3 pro Bridge problem
02-13-2020, 03:26 AM #1
- Feb 2020
I have a problem printing a bridge, i want to print the attached model.
My problem is that when the nozzle is printing the cross part and it reach the center, it change the direction to 90° instead of printing from side to side of the cilinder, that causes a drop of some material.
What can i do to print it right?
I use cura 4.4 to slide.
02-13-2020, 11:17 AM #2
Mesh mixer has where you click on the desired spot to add a support.
You could load your model into ThinkerCad Online and add a single center support, then save the new model.
02-13-2020, 12:06 PM #3
- Feb 2020
Adding a support is the only solution? There isn't any configuration to make the printer do two normal bridges crossed instead of printing it with with a 90° direction change from the center when printing the bridge?
02-13-2020, 08:12 PM #4
I do not know of a way, someone else may have a solution then we will both learn.
