Results 1 to 10 of 11
Thread: 200:1 gearbox
01-20-2020, 06:16 AM #3
- Jun 2015
- 46
I appreciate your reply
I believe it will work
https://photos.app.goo.gl/9SNBbwsqsMDpLjhTA
Since I found the circumference scale
It said a 8cm diameter has 200mm meaning a 5:1
Planetary can have 40 points that are 5mm apart and the one tooth can make 200:1
Which would be better then cyclodial
Obviously I want to test it
I have most of the file
I am about to get this completed I will keep you posted
Not only will it work.
It will work better then other gears because two teeth will push and it is being pushed instead of rolling making it have even more torque than normal gears that rollLast edited by jamesmatheson; 01-20-2020 at 06:47 AM.
