Thread: Few beginner questions..
01-08-2020, 09:07 AM #1
- Jan 2020
- 2
Hi,
I dont see how this forum doesnt have FAQ or a compilation of same questions we might have.. my model is elegoo mars.
I swear the manual of elegoo mars is smaller than anything ive ever bought.. even usb had more information than this product..
1. Do I need to adjust the platform after each resin print? You take it off and then use spatula or other to take of prints from the platform. Do you people need to readjust it?
2. Do you really have to pour new resin after each printing and filtering the resin after each print? Even if it takes small amount of time to print?
3. Do you use same resin and keep printing? No one mentions these things... weird..
4. Is it pointless to wash nitrite gloves after you use it? Seems very unfriendly enviromentally if you use it for 10seconds while taking the print out and clean up.. All I feel it takes around a 1 min of use..
5. Ive seen a guy who washes the resin tank after printing one puny, tiny model.. Cant you keep printing or you must wash it after every tiny piece of thing you just printed?
Thanks.. I hope someone who has experience can answer these.
01-09-2020, 07:59 PM #2
- Aug 2015
- 256
No, not unless you didn't tighten the platform well enough or really torqued on it.
It is best practice, if you have some tiny chunks of cured resin they could be pushed down onto your lcd screen and cause damage. However, I don't bother if I'm sure my previous prints came out without any problems.
Yes, but it's best to stir it up when adding more
You can wash the gloves and reuse, but the alcohol used to wash the gloves cost more than another pair the gloves. Latex gloves are biodegradable, so you aren't saving the earth by reusing them.
You don't need to wash every time, this is especially true if you can print on another part of the bed. If you print on the same part of the bed as a previous print without washing you may risk losing some detail due to residue buildup, but frankly it's a very minor concern.
01-10-2020, 07:46 AM #3
- Jan 2020
- 2
Thanks, it seems i dont need to worry about it too much.. but again..
I checked the container where the resin is poured and.. while it was brand new it was not perfect ideal. I tried with no weight clean it up with microfiber but it seems its not dust spects but plastic bottom itself. Its only seen if I look directly to the lamp bulb but.. still.
Is it big deal or no?
Im not sure, and not many say how fragile or robust these things are, or how long they last or how delicate we must be by using them.
Again, thanks for help!
Today, 02:02 PM in Tips, Tricks and Tech Help
