Thread: One tooth gear
12-26-2019, 02:21 PM #1
- Jun 2015
- 46
One tooth gear
I need this
https://anime.kenmaz.net/view/anime/2911894
It is a one tooth gear
It is a planetary
https://photos.app.goo.gl/wwEcLtuG9h3kiRHz7
With this on top
https://photos.app.goo.gl/ynBmdLC1N5ATSqZK6
Like this but attached
https://photos.app.goo.gl/pFVhDWeFtf8n7mk67
With this arch in each tooth
https://photos.app.goo.gl/PE3XtowoNhp8L4y36
To make sure the motor gear always arches the right direction
Please let me know what you think
Or if you have a one tooth design
12-26-2019, 04:34 PM #2
- 885
It would be easier to understand your objective if your drawings were closer to a standard engineering drawing. The animated one is sufficiently jerky as to make the movement impossible to understand. Have you seen similar gearing on the internet that you can paste here as a link? A search using The Google results in nothing resembling your sketches, but there is a video from the YouTube: https://www.youtube.com/watch?v=59AI77p5KAc that shows an approximation of a single tooth gear.
The concept of gearing requires and implies more than one tooth to be considered an accurate description. Even an escapement has two teeth to function.
More details or a better set of sketches would be helpful.
12-26-2019, 04:48 PM #3
- Jun 2015
- 46
Thanksfor your reply
It would work with two gears no question
But like shown
First theres the planetary gear at the bottom.
Then the long poles to make the gear turn.
Then the pole in the sun gear to complete the rotation
If it was one gear when the one gear cleared the bottom gear it would get locked unless it fully cleared the bottom gear and to make a rotation after it fully cleared would take 270 degrees which is equal to two a full circle
And a full circle is the same as two gears
It there was a way ( which there isn't )
To make it so a 180 degree turn in one tooth then it could a turn but it needs 90 degree to make a turn or it will.take two gears
So in short it needs two gears
And the YouTube is for a different application
If you want.to make a two gear system
I am looking for a developer
Thanks for your reply
