12-12-2019, 11:48 AM #1
- Feb 2014
- Tyler, TX
- 18
Can't find setting in Merlin code
I have made several adjustments in the configuration.h file to suit my custom 3D printer, but there is a setting that needs to change that I can't find. After homing all axis the extruder then moves out in the X direction about 40 mm. I need to change that to about 15 mm but I can't find that setting in the configuration.h file. Can someone please tell me where that setting is?
12-12-2019, 03:33 PM #2
- May 2018
- 561
Do you mean when the print starts? When the extruder moves off the platform to purge? Is so that is in the slicer script code
12-12-2019, 07:41 PM #3
- Feb 2014
- Tyler, TX
- 18
Where is the slicer script code? I am using MatterControl and MatterSlice.
12-12-2019, 09:55 PM #4
- May 2018
- 561
No idea.. just know it is in the script tab of S3D.
From Simplified 3D for my printer
G28 ; home all axes
G1 Y50 Z0.3 F9600 ; move forward to avoid binder clips
G1 X205 Z10 ; move off platform
G1 Z0.4 ; position nozzle
G92 E0 ; zero extruder
G1 E25 F225 ; purge nozzle
G1 X190 Z0.1 E1.0 F1200 ; slow wipe
G1 X180 Z0.25 ; lift
I would assume if the software has a profile for your printer it is in that profile.. just guessing
12-13-2019, 07:50 AM #5
- Feb 2014
- Tyler, TX
- 18
Thanks, I'll see if I can find it.
